• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Boat Unable to Plane Under Load
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Boat Unable to Plane Under Load
    I recently bought a '94 Tracker Deep-V 17' alum. boat (weighs about 1000 lbs) with a mercury 40hp motor. The boat was checked by a mechanic and all was fine. When I take the boat out with a large load (3-4)people and gear it will not plane and only travels at 5-10 mph. If I take it out alone it does fine 25 - 30 mph (but a little slow to plane). A firend suggested a different propellar. The prop shop suggested a larger engine. This engine is the standard with this boat and Tracker Marine sells alot of these boats. I don't think I need a bigger motor but rather this motor may have problems. Under load it will not exceed 3000 rpms, but when not in gear it will rev. up to over 5000 rpms. Any ideas? and does it harm the motor when I take a heavy load out and run all day at 5-10 mph? Thanks for your assistance!
    Re: Boat Unable to Plane Under Load
    What size pitch is the prop you have on at the moment ? You must have a rev counter if you say it will rev up to over 5000rpm out of the water (which is NOT a good idea !) What are the max rev's that you get when you are in the boat alone at full throttle ? I would say you have the wrong prop on. Don't run your motor at full throttle if you are only getting 5-10 mph - you are putting severe strain on it. Lets know the answers to the above questions and we can help further. For now we will assume that the compressions on your engine are ok if you had a mechanic look at it.
    • #3
      Ahoy, Basser. I'm with your prop shop. BPS offers Trackers as bare-bones cheap boats with the cheapest (read: smallest) engine they can find that will plane it with a 120# teenager and one gallon of fuel (exaggeration for impact). They overdid it with the Deep Vee 17 and now offer a 50 as standard on that boat. I think it is rated for 90 to 100hp. Check the ratings plate attached to the hull somewhere. My 950 pound Whaler 17 is rated for 100hp.The minimum hp needed to perform well at full load (listed on the rate plate) should be about 70% of the rated hp. Half the rated hp should do well with light loads. I suspect that you have less than half of the rated hp.Red sky at night. . .JB
      sigpic
      • #4
        I recently bought a used Tracker 17Fish deep-V, and it has a 90 on it. Based on how mine performs, I would say a 40 would be definitely undersized.
        • #5
          Thanks for the responses.The boat is rated for a 90 hp max. The typical rpms when I am boating alone is around 4000 to 5000 (I've only been out once on it alone, not real sure). I do not know the pitch for the prop, it is the standard prop for this motor. The prop shop mentioned that the pitch was 13 and I could try a 10, or vice versa, and they indicated that if I traveled alone I would have to switch back to the other pitch to avoid damaging the engine. It sounds like a new motor is the solution; would 60 hp be enough? As suggested by JB, this would be 70% of the max rated hp for this boat. I plan to often have up to 4 people on board. Also, I do recall the mechanic saying that the compression in one cylinder was 10 less than the other three, but he felt it was acceptable and should not cause a problem. This was over six months ago, I wonder if the compression could have gotten worse and maybe creating part of the problem, also this engine has not been tuned in several years, it ran smooth out of the water and thought I would wait until after this season to tune it. Thanks again for your assistance.
          • #6
            I think a 60 would do well, Basser. A 70 would do even better than that if the budget permits. By the way, your engine has two cylinders. If one is down 10# to the other it is not a big deal as long as they both exceed 100#.Good luck and let us know what you do.Red sky at night. . .JB
            sigpic
            • #7
              Hello fellow alum boat owner, I purchased a 96 Starcraft fishmaster 170 with a 75hp force i belive mine weights a little more around 1100. I had a 17pitch and could only go 15mph(3450rpms) then I droped down to a Hustler 13 wow (4300 rpms) 25mph. I have since returned the prop and droped down to a 11 pitch but have not tried it yet. I am guess I should get around 4700 rpms and gain 4 miles per hour
