Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Leaking Trim Pump
  • Leaking Trim Pump
    Hi! I have a 87 Mariner 1987 135 hpThe trim tilt pump has started to leak.It seems to leak mostly when the motor isin the down position (although occassionally when it is tilted all the way up too) Leaksbad when motor is down, you can see fluid in the water. My question is this, any certain seals orings to change, or should I just change every seal? No work has ever been done on unit since new.
    Re: Leaking Trim Pump
    IS this V6 and can you see leak?
    Help somebody every day, if you can.
    • #3
      Yes it's the v-6 marathon model. It is visible in the water. Now the motor is fully tilted up and looks like it's leaking near the bottom part of the assembly, near the two trim cylinders and the tilt cylinder
      • #4
        I think you can get seal kit from merc for the cylinders. The o-rings for motor and pump were were hard to find, I now have source fro them.
        • #5
          Clanton,Thanks for the help. What do you recommend?Replacing all the seals? What's the contact info for your source for the parts?Many Thanks again
          Back to Top
