• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Correct Spark Plug for 1974 Merc. 7.5 hp
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Correct Spark Plug for 1974 Merc. 7.5 hp
    Last week I had put up a post about my Merc. 7.5 hp having troubles starting. The motor runs great when I get it going, but have a hell of a time getting the thing started. The only way I can get it started is by tilting the motor out of the water and pulling it about 15 times or to put wd-40 in the cylinders. I've done a little research and believe I've been using the wrong spark plugs. I've been using a champion L78v plug when I think I should be using a Champion L77v plug. Does anyone know the difference in these two plugs? Could this be my starting Problem? The l78v is a no gap plug. Any help would be appreciated.
    Re: Correct Spark Plug for 1974 Merc. 7.5 hp
    Bosch BR9HS-10,Champ L77V.But I think your problem will be carb ot fuel pump related,given what u said about the WD40 and tilting ritual before it starts.
    "Did you hear about the guy whose whole left side was cut off? He's all
    right now."
    • #3
      Hi,If you get it going, it will run the best with Champ L77J4C gapped at .040....have fun...corm
      This is free internet advice.
      Have Fun,
      corm
      • #4
        Thanks alot for you advise. I'll give it a try. I should have mentioned that I've replaced the fuel pump diaphragm and gaskets, also the needle seat and checked all the jets in the carb. I've also replaced the primer bulb and fuel lines and checked the fuel line filter. I've been working on this problem on and off for the last 3 yrs. Even had it in two different shops and they counldn't find the problem.I don't think they tried real hard though. I was messing around with it today and it seems like the bottom cylinder isn't getting the gas like the top cylinder is. Both cylinders are working when its running, because I pulled one plug wire off at a time and it keeps running on one cylinder. Not sure what to try next. Any more advise would be apprecaited
