• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Merc primer bulb won't get hard
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Merc primer bulb won't get hard
    Can anyone suggest why my primer bulb wont get hard. It's a new bulb, no anti siphon device in line. ?Bad bulb??? would fuel pump sealing or check valve cause this??
    Re: Merc primer bulb won't get hard
    It may be the primer bulb,EVEN if it is new.There have been a bunch of bad ones found.But one question, does gas leak from the carb(s)?
    "Did you hear about the guy whose whole left side was cut off? He's all
    right now."
    • #3
      Never seen gas leaking from carbs, I feel like I can't get any gas to the carbs. We have fuel tank, water separator, bulb, fuel pump, inline filter, carbs in this order. You'd be there a long time getting the see thru inline filter full of fuel. I usually give up when I can get it 1/2 full, then it usually starts, with a little choke and throttle maybe. I feel fuel moving in the bulb, feels like it comes in from the tank and right back to it,with a little going the right direction each time. Bought fuel pump kit to put in this weekend to stop gas leaking from pump (I've only seen this happen when I'm lucky enough to get the bulb hard). Almost bought another bulb too, but I can get one later if need be, Know how to test a bulb, or where would you look next, I'm planning on the fuel pump kit not solving all the problems...
      • #4
        Hi Grandx Not to be smart but did youconnect bulb in right direction. Regards Tom
        • #5
          LOL,yea boatmotor,it don't hurt to ask, but mine did that on my 120force and 7.5merc, and it was a new primer bulb in both cases. But yes, that would give the same result Also, remove the pickup tube from the fuel tank. If it has a little ball inside of a cage-like thingy on the end of the tube,take it off and sacrifice it to the toilet-god.It's a worthless device called an anti-syphon check ball,and it will never work the way it was designed to...So toss it.
          right now."
          • #6
            no anti siphon in line, and yea, no offense taken here, but the bulb flow arrows are pointed to the engine and not the fuel tank. I welcome all possibilities, keep em coming. I'll bet between us we have it fixed by Sunday.Thanks for the posts
            • #7
              Had this problem for years with my O/B for me its been the floats in the carbs, I think that they are not/stop seating in the bowls. Samething as you? hard to start,must choke and throttle to start engine.My problem is the boat stays in the water for the season, so I keep the engine tilted up and some of the gas runs out and the floats aren't seated when not using the boat and this is letting the floats get stickey?? What I do is remove the overflow hose on the carb and spray crab cleaner gum out in let it sit 5min and start the engine to run it out.It's allways worked for me.Good Luck
              • #8
                I put fuel pump kit in, leak stopped, put a new bulb in. Engine seems to idle fine in the back yard with garden hose hooked up. Plan on going out next weekend, will post results next Monday.dg
                • #9
                  Motor ran fine this Saturday, thanks for everyone's input. Looks like I discovered a leak on top of the trim cylinder though. I'll try my hand at this next. Thanks for everyone's help.
