• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Mercury outboard stalls
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Mercury outboard stalls
    I have a 1979 mercury 900 series 90H.P. motor. The problem that I'm having is that when the boat is idling and I go to jump on it the motor dies out. If I bring up the throttle slowly it runs great threw the full throttle range up to 4600rpm. I just had the whole distributor unit replaced.(very expensive)could this be the carburators not set right or maybe the plugs going bad. Please help, Thanks
    Re: Mercury outboard stalls
    Yes, weak spark will flood the cylinders withunburnt fuel, and the motor will hestitate badly.But it allmost surely would miss under continuous throttle. But change the plugs with a fresh set.Run the motor to operating temp.Gun it till it stalls.Pull the plugs. Are they wet or dry?WET, weak spark or too rich fuel. Turn the idle mixture screws counter clockwise 1/4turn.DRY; Too lean mixture. open mixture screw 1/4turn.------------------Time to change my tagline
    "Did you hear about the guy whose whole left side was cut off? He's all
    right now."
    • #3
      SET YOUR CARB MIXTURE SCREWS TO 1 3/4 TURNS OUT FROM LIGHTLY SEATED AND MAKE SURE THE THOTTLE SHAFTS ARE SYNC PROPERLY THEY SHOULD BE COMPLETELY CLOSED AND SHOULD ALL OPEN AT THE SAME TIME YOU ADJUST AT THE BLACK PLASTIC SHAFTS THEY ALL NEED TO OPEN AT THE SAME TIME OR IT WILL BOG
      • #4
        Mike, bogging on acceleration is a common problem on these engines...is almost always a carburation problem...unless distributor/timing was incorrectly done.....curios about model year, I thought last year for distributors on these motors was '77.....next time you are out in the boat and it is bogging tap the choke and see if the motor pulls out of the bog.....if it does you are lookig at a fuel prob.
