• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
mercury outboard alarm
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • mercury outboard alarm
    This weekend I dinged the propeller on my 1989 Mercuury 90 on a rock, ripping a piece the size of a dime off one blade. Now whenever I turn the key on, an alarm sounds (steady beep, which I am told is overheating). The alarm sounds with the key on even if the motor is cold and not running. Does anyone know how I can diagnose this problem?
    Re: mercury outboard alarm
    Hi DHobber,If you still need an answer it is the oil warning module (small black box on starboard side of motor) with 5 wires comming out of it.It is mounted below the starter. Or the temperature sending unit back by the sparkplugs.The wire comming from it goes tothe the module(tan/lt.Blu)unplug it,see what happens.Also unplug your LT.Blue wires goingtothe oil sender in the oil tank. If the horn stops you have found the problem....hope you got fixed already...corm
    This is free internet advice.
    Have Fun,
    corm
    • #3
      corm is correct, it may very well be the warning module. I'd advise you to go one step further. Take your boat to a experienced boat mechanic. A waring horn system is not something to take for granted. Most engine com****** spent several million dollars trying to make sure you would know if there ever was a problem. Don't just disable the system. Get it fixed! Good luck !
