• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
1988, 200hp mercury, no spark
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1988, 200hp mercury, no spark
    Not getting any spark. have disconnected the black w/yellow tracers from power pack. both leads are showing grounded. Don't know where to look next.
    Re: 1988, 200hp mercury, no spark
    hi there i have the same engine and year .....I would check ignition switch....then go from there......then to the trigger and stator under the flywheel.....good luck
