• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
tach problems
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • tach problems
    Greetings,I purchased a 1983, 50 HP, 4 cylinder Mercury. I decided to install a tach. I purchased a Teleflex tach off E-Bay. It was new and still in the package, never opened. Went to my Mercury dealer and purchased a wiring harness that goes into the remote box. I hooked the tack up per Mercury instructions (purple to ig, gray to sending and black to ground). I set the dial switch to 6P per Teleflex instructions.Went to water and it showed 4000 RPMs. WOT should be 5000-5500. My prop was a 14 pitch. I decided to move to a 12 pitch in order to bring RPMs up as well as get better hole shot. Installed prop and she came out of the water but the RPMs is still at 4000 WOT. I checked the connections and re-read the instructions about the dial settings. 6P is where it should be.I have a Sears Engine Analyzer I use to work on my old truck and my old Mercruiser. It checks RPMs, Dwell. amps, volts, etc. Can I use it on an outboard to check to see if my new tach is bad? The way I use it on my truck is to hook the cables to the battery and a lead to the coil and one to the alternator. What else could be wrong so the tach does not go above 4000 RPMs?Thanks,Terry G.
    Re: tach problems
    Sorry your engine analizer will not work. Check this link out to see if it might help you?? web page
    • #3
      Re: tach problems
      I e-mailedTeleflex and this was the reply:HELLO AGAIN TERRY,I'VE GONE OVER DATA GIVEN US BY MERCURY MARINE AND IT SAYS 45 HP THRU V6'S HAVE A 12 POLE ALTERNATOR WITH 6 PULSES PER REVOLUTION (6P). HOWEVER THEY DO NOT SPECIFY MODEL YEAR. SUGGESTION WOULD BE TO HAVE A SHOP MECHANIC TEST THE ACTUAL RPM FOR YOU. BY ROTATING THE SWITCH TO 5P, 4P ETC., WILL INCREASE THE READING. ALTHOUGH MERCURY SAYS 6P, YOU MAY HAVE TO ADJUST THAT SETTING TO MATCH THE MECHANICS RESULTS. MERCURY'S CUSTOMER SERVICE # IS 920/929-2323.Do you guys think this is the way to go?tg
      • #4
        Re: tach problems
        Thanks Trent.I wish I could get some more advise on this matter.tg
        • #5
          Re: tach problems
          TerryYou're going to have to borrow a mechanical tach for the end of the crankshaft, or optical/strobe tach to check the accuracy of your electronic tach. There is no better way.....
          Alias "schematic"
          • #6
            Re: tach problems
            Thanks Mr. Schematic.I really appreciate your input, and I learn so much from your posts. I'll track down what I need and get started. Take care.TG
            • #7
              Re: tach problems
              I have a '81 Mercury 50 HP 4-cyl. I recently installed a new Quicksilver tach. I set it to 6P as per the instructions and it works fine. The motor idles around 700 RPM. It revs at 5400 RPM at W0T with a 14 pitch propeller on a 15.5' fiberglass boat. What size/weight of boat do you have?Here's a link to a page on Mercury parts site with tachometer settings... http://www.mercurypartsexpress.com/P...re=Accessories The line "Mercury/Mariner (2-stroke) 45 thru V-6 (U.S. Origin)" is the one that applies.I hope this helps.Regards,Russell
              • #8
                Re: tach problems
                I too added a tach, and while it seems to work great, I have a question...When I turn the motor off, sometimes the needle will creep up to around 1,000 RPM's, this is AFTER the motor has been turned off? AS soon as I turn the key one click (NOT all the way on) the needle comes back to ZERO?Is this normal?THANKS!
                • #9
                  Re: tach problems
                  BBogey Because of your meter movement style (balancing coil) it is normal not to remain on zero. It should zero when key turned on.....
                  Alias "schematic"
                  • #10
                    Re: tach problems
                    Thanks very much, you've given this rookie boater one less thing to worry about!
