Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
40hp merc outboard have thermostat
  • 40hp merc outboard have thermostat
    I have a merc outboard 40 hp ser#555407 Does this have a thermostat? water does not come out of tail tale stream at idle.any help would be appreciated
    Re: 40hp merc outboard have thermostat
    Tex,Had this problem with my Mariner and got awsome help on this board. Turned out that I had trash in the pee hole right at the outlet. Try cleaning that first with a straightened paper clip or a pipe cleaner and see if that don't fix it.When did you last change the pump impeller?Case
    • #3
      Thanks for the quick responce ill try cleaning the hole. its been about two years i guess its time to change
      Back to Top
