• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
150 Mariner - burning too much oil
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 150 Mariner - burning too much oil
    I have a 1996 150 Mariner (2.0) that is burning too much oil and having trouble cold starting. I think I may have caused it myself by putting a new fuel line on in reverse (real smart huh!). I primed the bulb several times which ended up sucking TCW3 through the pump and 2psi check valve. Then realized my stupid move and switched the hose around. To make matters worse, one of my equally absent minded fishing partners had knocked the arm off of the oil pump which meant that the outboard was being run with the oil pump maxed out for the next couple of fishing trips.Since then, my engine has failed to cold start on several trips. The plugs are always fouled with wet oil when I have trouble cold starting. I can get it running by cleaning the plugs or using ether (I know, bad move) but find that it is pushing plenty of smoke and plenty of unburned oil is hitting the water.Do any of you think that I've damaged the oil pump or the 2psi valve or both??? Or is the "wrong oil pump end plate" problem that ODDD1 has mentioned in the past a contributing factor?Please help?!
    Re: 150 Mariner - burning too much oil
    Pawpaw1, thank ODDD1 I am checking out oil pump end plate problem and the 2 psi. check valve in the spring. Boat in storage now. Go to your local Mercury Dealer only and have them run your serial number through Mercury Marine. That is what I did and I might have thje wrong oil end plate. But still open for other ideas. Have a Merry Chritmas
    • #3
      Ok, both you guys...the end plate prob was SPECIFIC to the 40 hp 4 cyl...never a v-6 prob....2 check valves you need to check, the oil output check valve [2 psi], of which i have replaced alot of, or the check valve that pressurises the remote oil tank with crankcase air...the air pressure valve is easy to check, after several minutes with the engine running, turn motor off and WAIT 4/5 minutes..unscrew the remote oil tank cap and listen for escaping air pressure...any air pressure found doing this means the valve is bad....if this one is OK, you can assume the oil output valve is bad and replace.......
      • #4
        ODDD1: One more question on the 2 psi oil output check valve. Clymer's said that this valve is in place to prevent gasoine from being forced into the oil line. Is this valve also in place to limit the amount of oil that can enter the fuel line when the motor sits up for a few days?I disconnected my fuel line this weekend and found that 100% oil was in the line. This is obviously why I can't cold start. Also, I thought the check vavle that uses crankcase air to pressurize the remote tank was one way. Should the pressure go down when the motor is not running? I can't remember my remote tank ever not being pressurized in the six years that I've owned the boat. If I remove the cap a month after the boat has been run, it still has plenty of pressure. I have noticed that the remote tank does look kind of bloated these days. Have I had a problem all this time without knowing it?Thanks
        • #5
          0pawpaw, that output check valve is in the line for another reason besides just separating the gas and oil...those mikuni oil pumps are calibrated to mix correctly against a 2 psi head pressure...if it is not there, they will pump too much oil....as far as your air press valve is concerned, it is bad...it should bleed off pressure when motor is off....in the old days [late 80's] merc didn't put the pressure bleed off on the check valves, and they changed them precisely for this problem.......
          • #6
            ODDD1: Thanks for the info. Hopefully I'll get this worked out. One more ruined fishing trip and I'm going to pitch the whole oil injection system.
