Ok, I need some help with my Mercury 90/65 (2002) 2-stroke, 3 cylinder jet motor. I was using it earlier in the year until it lost power - suddenly, at top speed it became about 2/3 of the normal speed for a few seconds, then recovered. Next time it happened longer and now all the time. It used to get top speed 30+ with just me, now just 20mph. Other than that it seems to work great; starts fine and runs great. I haven't been using it much until I can figure exactly what's wrong.
I have tried the following:
Changed spark plugs
Changed fuel filter
Removed and cleaned carbs (they were really clean; and floats moved free)
I also noticed the charging circuit on my battery voltage was crazy (flipping -100 to +100volts); so changed voltage regulator and now that is Ok but boat top speed didn't change.
I did have electrical fire in the motor 2 years ago; ground shorted out and melted a lot of plastic wires. I used some electrical tape and it worked fine - so repaired the wires that were melted and the motor was fine for the next year.
When using an inductive tachometer (very cheap one); I see lower chamber runs 1000rmp while top two would sit at 2000rpm testing last week. This week the same setup the lower one shows 4000rpm; which I know isnt' right. But it's different to the top two. Based on this I'm suspecting the Trigger may be bad (possibly Stator too, not sure). I've ordered a new trigger to try out which comes in a few days; since that's cheaper.
I've moved the CDM module between two spark plugs but the RPM's reported didn't follow; so I don't think that is an issue (unless my really cheap tachometer is lying to me - I've ordered another as a backup getting here soon).
Could a bad Trigger cause a loss of top speed? My guess is currently something with the CDM; trigger or Stator?
Any other ideas, or if I'm doing something wrong in diagnosis please let me know and send tips!!!!
Thanks
James.
Changed spark plugs
Changed fuel filter
Thanks
James.
