Carpcatcher
- Mar 5, 2018
- 12
Can anyone tell me the compression spec's on a 1994 Mercury 90hp 2 stroke motor???
Post your numbers !
If gauge is a good one I would take off the exhaust cover to have a look at the pistons rings.----Perhaps test with another gauge first.
Good luck with it.
Thanks for the response "racerone", we bought the boat last week, '97 Sun Tracker 21', the people said they didn't use it much and had been sitting since last Oct. We have not had it out yet to see how it will perform on the water. I'm hoping it will do OK. The idle is a little rough when we run it in a bucket. I don't want to open up the inside of the motor until I see how it runs on the water.
Yeah! Per the manual: "if compression is less than 120 expect problems".
