You will want to replace the impeller, wear plate and the two gaskets that sandwich the wearplate. There is a kit for this.
Inspect the stainless steel insert in the pump cover. If it has scratches, replace the upper pump cover as well. There is alos a kit for this. Sierra makes both as does GLM and some others.
