BillyGibson
- Mar 10, 2018
- 2
I'm having problems with the trim switch operating in the up position. Down works fine and trailer works fine going up but trimming up does nothing. I pushed the plunger in at the trim limit sensor and the switch works. Do these plungers get wore off because it appears the tab that pushes the plunger in doesn't push it in far enough. Also, is there a specific way to adjust this type of switch. I know it can be adjusted just not sure of when it's properly adjusted.
