liquidcommotion
- Nov 3, 2009
- 10
See if you guys can help me out with this. I have a 25hp mercury I just picked up has good compression, needed a stator so I replaced that, while I was in there also replaced the ignition trigger, and the spark plugs now I have spark in both cylinders and no fuel so I cleaned and rebuilt the carb........wont start but will get a backfire out of the exhaust. I tried swapping the Ignition coil wires as it seems like a timing issue. I advanced the trigger with the coils switched to either cylinder.......the reid valves physically looked good when I had the carb off...............what am I missing? A backfire out of the exhaust means fire in the hole so is that definitely some sort of timing issue? It's a brand new trigger.....Thanks in Advance!
Nautical Ailments
Nautical Ailments
