jvilla2113
- Sep 13, 2012
- 3
I just bought a 2003 tracker with a 90 lepto. I'm barely able to move the shifter to reverse, maybe 10 degrees, Just barely enough to engage the shifter on the motor into reverse. If I push the advance throttle button it will go all the way down in reverse. Forward gear works fine. Any ideas where I should start? I don't think the problem is in the lower unit since it will engage both directions but I've never had a control box apart.
thanks in advance!
thanks in advance!
