Not new to boating but new to outboards. Bought a fishing boat with a 2014 115 Merc 4 stroke and now it’s time for a service. Checked a couple sources that identify draining the motor oil through a valve/plug located on the starboard side of the engine. Well, no.
Actually, the plug is located on the port side and is not a plug/ valve but a simple plug. It’s slightly recessed compounding access for a tube or funnel to contain and direct the oil. As I went through the process, it made quite the mess, running down the side of the motor and dripping off the fins on the leg.
There’s GOT to be something I’m missing, as far as the mess goes.
Any suggertions would be appreciated.
Thanks in advance.
Thanks in advance.
