My 1977 Mercury 1150 trim cylinder is leaking out of the piston rod at the retaining cap. My trim has the 3/4" piston rods. I know this is probably just the 3/4" o-ring in the cap.
Should I just find an o-ring locally to replace the one that leaking or buy the Mercury kit and replace them all? The Mercury kit is #64507A1 for the entire cylinder.
The o-ring locally would probably be a dollar or two. The kit from Mercury is probably $45 per cylinder.
Thanks,
Kevin
Thanks,
Kevin
