Shannon S.
- Dec 10, 2017
- 4
Hello All,
I recently purchased an old (I think it's a late 70's model) 8 hp Mariner. The guy I bought it from said it ran great. He even had it in a barrel of water when I got there so I could hear it run and it did run fine. I bought it because I thought it was a pretty good deal ( $325) and it came with a gas tank. My only concern was this guy said he had the motor for 3 years and hadn't done any work to it. I have worked on other outboards before so I knew I could work on this thing. My plan was to replace the water pump impeller and maybe do a carb rebuild. However, much to my dismay, upon getting this thing home and scouring the internet I've found most of the parts for this motor are no longer available. I can get the impeller but there are very limited parts available for the water pump and zero parts available for the carb. I am already starting to regret this purchase. I guess my quesitons for help would be:
Besides the impeller, are there any seals and O-rings I should replace in the water pump?
If I cannot get carb parts for this thing, is it possible to outfit it with another carb?
Thanks.
Thanks.
