I have called mercury Marine and looked in the manual. There is no info on how to remove the throttle shaft located in the tiller. The schematic shows a bolt and a bracket on the underside that looks like it is holding the throttle shaft. I removed the bolt , but didn't want to force anything.
Is this bracket the one that holds the throttle shaft? Should I just tap it a little to get it out?
