I have a 2001 90 horsepower Mercury outboard starter. I went in to change the bushings and clean out the starter. I put the starter back together everything seemed fine the starter spins forward and backwards by hand but when I went to bench test it the positive side gives off a spark and starting to melt the screw on the positive terminal for some odd reason the screw is getting real and the stater wont turn...did I put something in backwards any help will be appreciated thank you...
Mav6759
Mav6759
