I have a 92 Mainer 40hp 4cyl.
The throttle cable has a black plastic end that attaches to the throttle lever. Should that black plastic end have play (about 1/2") back and forth on the cable?
I'm trying to make adjustments as per manual, but when I go from full throttle to idle I noticed the idle screw wasn't touching the backstop from when I previously set. I realized I could move the black end of the throttle cable out with my finger so the idle screw touches the backstop
As you can see in the images, the idle screw is against backstop, when I put in full throttle, then back to neutral, the idle screw is not against the backstop
Is it normal to have about 1/2" play in the throttle cable end?
