Hello, I have recentely aquired a pontoon boat with a 2005 50 hp mercury 4stroke SN 1B282668. After some reasearch on what the part is called I learned it is a fuel cooler? It is leaking fuel from the top, there seems to be a top cover plate with two screws holding it on and I have been trying to find out if there are replaceable o-rings or a gasket that is available to repair it. I have seen the part is quite expensive so I wanted to see if it was repairable. Thank's in advance for the help.
