Dirk Diggler
- Apr 3, 2010
- 25
Is this the results of using ethanol laced gasoline?
This is the primer housing and primer diaphragm. The only thing left is the mesh like material that the rubber is bonded to.
Can I assume that the fuel pump diaphragms are going to suffer the same fate?
I just got this motor. It seems to run fine. I just noticed fuel blowing out the weep hole in the primer body when the enricher plunger was cycled.
Edit: will post pics later. Pics are too big.
