Steve the greek
- Aug 10, 2011
- 39
Hello again
WellI started pulling down the Mercury 1150
as I took her out on the lake and she ran like a dog.
So I though would check electrical harnessand pull off the 3 carbs and give a good clean.
Question the wires connecting to the SWITCHBOX ASSEMBLY from the harness 3 or 4 of them were that rotten they were all exposed wires touching each other. ( Can that cause electrical problems ) ??
Question 2 When pulling off the 3 carbs WMK
It seem I have 1 WMK 151 top Correct
The next 2 carbs marked WMK 153 ( Where is WMK 152 ) or that does not mater ??
Question 3 As I want to put a carby kit through these 3 carbs
Can I just replace all components that in the kit.
And if so Can I just pull out old ones including Idle jets and main jets ( OR DO THEY HAVE TO BE SEATED A SPECIAL WAY ) ??
as I'm keen to just replace and get boat back at the lake.
I would appreciate all your comments on these 3 points
And thank you for your assistance
Cheers Steve
Sydney Australia
Cheers Steve
Sydney Australia
