is the fitting that is threaded into the VST tank at the bottom suppose to be a check valve type. I was servicing my VST tanks on my 2 motors and noticed that one allows easy blow thru and the other requires a little pressure. The one that requires pressure also acts like a check valve and does not allow backflow from the tank . The tank fitting on the other tank allows both ways . Which is correct ? My manual just shows a diagram that oil goes int the tank at the fitting .
