Motor runs awesome but it randomly blows the 25A main fuse after I shut it off. I haven't been able to determine how long after I shut the motor off that this happens. When this event happens there is an excessive active draw off the battery. When I put a new fuse in the new fuse will at times immediately blow the second it is seated into the harness. OKAY... disconnected the main wiring harness on the motor to determine if problem is on motor or elsewhere in boat. Problem remains when main harness is disconnected therefore determine issue to be on the motor. Long story short and many tests later I replace the volt-reg/rectifer, stator, control module (ign switch) and battery. After these "repairs" I still randomly experience the fuse blowing in the same manner as described above. SO... the last time this happened to me I removed the plastic flywheel cover and manually turned the flywheel/eng crank about a quarter turn and the active draw disappeared. IN CONCLUSION what could be causing this? Obviously a dead short or closed circuit someplace when there should not be. Solenoid? Trigger? Wiring harness dead short not obvious to the naked eye? I have retested the volt-reg/rectifier, stator & control mod and all tested good. (even the old ones tested good - I simply assumed one had an intermittent fault that I would never track down) Love iBoats! Thanks in advance for the feedback! MJ
