Hi,
I noticed while testing a stator with stator leads swapped for testing, the motor would not start and the starter gear did not disengage. In the normal stator lead configuration the gear does disengage.
What might cause this? Is there some leakage/short that could bleed over to the starter solenoid line that would cause this?
I just recently replaced the starter solenoid switch a couple months ago.
If the starter gear remained engaged while the motor was running could that smoke some electrical components like the stator, trigger?
Thanks in advance.
Thanks in advance.
