son of water
- Jun 29, 2016
- 2
I thought I posted this somewhere but I can't find it. So I finally found a 40 hp 1986 6E9421313 to go with the tiller handle I had on hand. The handle and throttle cables were easy enough to install so next is the wiring for the ignition push button and the kill switch. It has a 7-wire cable that went to the remote so I'm guessing a couple of those wont be used but I may need a simple hand drawing to actually hook em up because I can't figure it out. Any help is greatly appreciated.
Black = ground
Red = battery positive
Green = tachometer signal
Blue = choke
White = kill circuit
Pink = warning ground
Brown = power to starter motor relay/solenoid
Black = ground
Blue = choke
