harrylewisjudd
- Aug 24, 2017
- 5
I?ve obtained a electric flywheel, solenoid rectifier and starter. The current motor has a switch box from whence the stator wires emit wiring for stator trigger and coils. How do I integrate new components into the system specifically the new rectifier. I understand the two wires from the stator attach to the stator and a positive lead then hooks into the system on the non-starter side of the solenoid. The question I have deals with the switch box and it?s wiring and function. If the wires from the stator go to the solenoid doesn?t that cause an interruption of current flow needed for the coils etc, do I need to split the wires from the stator and connect to both the switch box and the solenoid for proper function.
