So I have been battling the water pump in my 2010 mercury 50 hp elpto outboard from the day I bought it used. Being a new boat owner I was not fully aware of how strong the stream your telltale should have. For the first few time I had it out water would more or less trickle out of the tell tale. After realizing this I ended up replacing the impeller and gasket and had the same results. I took it all apart again and blew water down there system through the thermostat housing also replacing the thermostat and gasket. I ended up finding a lot of small stones and debris. After doing all of this I now have no water coming out at all and the over heat alarm goes off ( continuous beep ). Completely lost here, any help would be appreciated
Thanks,
Andrew
Thanks,
Andrew
