Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Outboard trim unit removed, can I still use the boat?
  • Outboard trim unit removed, can I still use the boat?
    I have removed my power trim unit waiting for parts and to repair it .
    My question, can I still use the boat on a manual trim like I do with my 9.9 and if so, how would I rig that up?
    Can i use a TILT TRIM PIN? or something like that to manually set the trim to a stationary setting?
    • #3
      What motor?
      BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        sorry, a 1987 mariner magnum 150hp 6 cyl
        ​Serial # ​B176526
        • #5
          don't think it has a "lockin' mechanism" like older and/or smaller stuff.. reverse would be useless... probably flop around like a loose tooth.. i'm thinkin' ya removed tha whole thing between tha clamp brackets?.. if you didn't then absolutely not!
          • #6
            Yes, reverse will be a problem, unless you go dead slow, and maybe have someone lean on the motor cover to hold her down. Use a tilt pin for forward thrust, and that should be fine.
            Also, you will want to slow down gently to keep the motor from popping up as well.
            • #7
              There is a lock pin bolt and there are holes that will secure the motor to the transom mount so it is possible. I was hoping there was a clip rather than a bolt.
              Turns out the trim motor kit came yesterday and I installed that so it works now..
