Sailboat engines were often a very long shaft. Propellers were often larger dia, and were combined will higher ratio gears. If the engine used a thru -hub exhuast some sailboat props were designed in a way that the exhaust wouldn't get in the prop blades while in reverse. In addition some sailboat engines had slightly different control.
My point was/is make sure you are comparing engines that are the same, not just the same hp
