Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
I broke my 60 HP four stroke charging system
  • I broke my 60 HP four stroke charging system
    I replaced the starting battery in my 2015 Mercury Four Stroke 60 HP and accidentally reversed the cables. Didn't see a spark or hear anything and when I turned the key on, nothing happened. I figured out what I had done wrong and corrected it. The engine and gauges all work fine, but it isn't charging the battery. I checked the fuses at the battery and they are fine.
    Are there other fuses in the engine and if not, what component is most likely broke?
    I think there a fuse under the cowl. I don't know where it is. If no fuse then, most likely the rectifier/regulator bit the dust. The R/R acts like a fuse when the battery is reversed.
    BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      There some fuse in another fuse older and probably one blow...........But the real problem is probably your diode , not the regulator/rectifire itself.
      ​The diode came whit a harness from Merc.
      http://forums.iboats.com/forum/engin...e-on-07-60-efi
      • #4
        Does anyone have a schematic of the charging circuit? 2014/15 Merc 60HP 4-stroke.
        • #5
          That diode is in the starter circuit. The motor starts just fine, it is the battery charging that isn't working. Can this diode affect the charging somehow?
          • #6
            I saw 4 or 5 times reversing wires on 60 EFI and every times one fuse blow repeatly and cant operate starter until changing the protection diode.
            ​Youre seems different problems .but You can check the diode whit a hometer.
            • #7
              I do not have a problem with the starter. The motor starts just fine. The problem is in the battery charging circuit. The battery does not charge when the motor is running.
              • #8
                I would test everything with a multimeter, its on youtube
                And CDIelectronics.com explains everything.on there site,
                Dont feel bad I did the same thing on a Force 125, there was a push button on a breaker and it was fixed.
                I quickly wrapped red tape around the positive battery lead.
