Slim massie
- Sep 20, 2017
- 2
I have a 1996 mercury 25 hp took it out on the water one day and ran perfectly fine for most of the day. Was headed back to the boat ramp and all of a sudden it cut out and died. Motor would start back up but would die when I put it in gear. After getting back home I put the muffs on it and it ran perfectly fine. So after reading a few things I decided to take the carb off and do a thorough cleaning of it. There was a little gunk in it but wasn't to bad and it appeared the float was setting right according to the specs I found for it. So I put it back in the water and same problem motor would fire up and idle way down then when put in gear it would die almost immediately. I have also changed the fuel filter and have put new fuel line and bulb on it with no fix. So now I'm down to thinking it could be a coil pack. Does this sound like a symptom of a bad coil pack.
Thanks for all the help.
