Hi, I have a 1996 15 hp mercury 2 stroke that starts well only with new lower plug.
Compression has been checked. Upper plug is dry and light tan on insulator.
Just changed:
Remote tank, Fuel hose, Fuel filter assembly, and new correct plugs
If I put new Plugs (correct according to manual) It starts 2nd pull.
Rans rough at idle low speed setting. Sounds out of balance at low idle setting even with new plugs. Offers to die unless idle in fast.
There is a ping/mecanical sound in early throttle increase in rpm's. I wear hearing aids so may not hear as you do
Smothes out at speed and runs well at full throttle. Difficult to restart. Lower plug is wet and there is evidence it is firing. black liquid on plug
Previously:
A year ago had hard starting problems and apparent overheating per merc tech. Mechanic did tune up and removed thermostat as In his opinion in our low temperatures said didn't need it. Said carb ok after "power tune" sprayed in motor. Compression Checked out ok. He could not get engine to idle at lower idle speed.
Have bad back restarting is tough.
Thanks for any help you can offer!
Just changed:
Previously:
