Ninnehoser
- Sep 17, 2017
- 4
I was replacing the top seal on the lower unit after rebuilding the water pump. When removing the bushing the shift rod came out with it. I can not get it back in. I tried turning prop but unable to feel or hear ratching sound. I can not get the piece in the hole to come even close to align the shaft back in. I tried the prop turning technique, turned the lower unit every which way you can think of. Does anyone have any other tricks without tearing into lower unit? Thanks for the help.
