sbwhip1782
- Sep 24, 2015
- 17
Hello everyone,
I have a 1975 Mercury 650 65 HP on my boat. The other day I was out cruising a little bit above 1/2 throttle. All the sudden the motor died. It took awhile to get her started again. When I finally did the boat would hardly move. If I tried to throttle down the motor would bog then die. I had to slowly putt back to the harbor. At home, while flushing the motor I noticed fuel leaking from the bottom carb. Could this be a carb or fuel pump issue? Any input will be much appreciated. Thank you in advance!
