Can anyone tell me conclusively if a Merc outboard flywheel has the part number 261-9007-c2 stamped into the steel on the top or bottom of the flywheel it is compatible with another flywheel with the same stamp? It seems that Merc has many part numbers for their flywheel depending on which model of motor that it is used on..Mariner also has this number stamped on flywheels of different horsepower and they use their own set of part numbers. I would be concerned with the size/thread of the hole as well as the strength of the magnets.
Thanks in advance.
Thanks in advance.
