opalized1
- Apr 5, 2017
- 64
I PICKED UP ANOTHER MOTOR, AND FIRED IT FOR THE FIRST TIME LAST NIGHT, ON MUFFS, FIRED RIGHT UP, ONCE I REPLACED STARTER, REPLACED ALL WIRING INSIDE COWLING, AND FILLED ALL CYLINDERS WITH WD-40 AND ROTATED FOR AWHILE TO UNGUM, ONCE FIRED EMMEDIATELY PEE'D, BLEW BUGS AND CRAP CLEAR TO THE BACK OF MY GARAGE ON INITIAL START UP, SEEMS TO RUN GREAT, BUT, I NOTICED WATER RUNNING DOWN EXHAUST PLATE FROM ABOUT HALF WAY UP ON SPARK PLUG SIDE OF PLATE??? DOES NOT APPEAR THIS PLATE WILL COME OFF WITHOUT SEPERATING POWERHEAD FROM UPPER UNIT, WHICH I AM GUESSING REQUIRES REMOVING TRANSOM MOUNT AS WELL AS UPPER UNIT??? ALOT OF WORK IT WOULD APPEAR, AND ADDITIONAL PARTS.
NOW IS THERE NOT AN INNER AND OUTER PLATE ON LEFT SIDE LOOKING AT SPARK PLUGS, AND IF ONLY OUTER PLATE IS LEAKING IS THIS A MAJOR ISSUE TO BE RESOLVED PRIOR TO USING THIS MOTOR?? IT APPEARS IT HAS SEEPED DOE QUITE SOME TIME, AND SPARK PLUG IN HOLE 6 WAS BRAND NEW LOOKING AS WHERE ALL PLUGS SO IT WOULD APPEAR NO WATER IS ENTERING CRANK CASE
