I just changed the impeller, put the lower unit back up, and now I have no reverse. I can change from forward to neutral, but when I put it in reverse, it is again in forward? When I was putting lower unit back up it stopped about 1 inch before, and had some resistance, I slightly tightened the nuts and heard click and then unit went in without resistance. I did not apply much pressure. Is this the case that lower unit is stuck in no mans land or in wrong gear?
