Hey guys,
My motor will only fire up if I disconnect the linkage to the trigger and advance it all the way.. Once running if I try to turn it back it dies instantly. It has blue spark all the time. Do i replace the trigger or switch box? (Flywheel key is in place) will not start with trigger connected and with spraying gas in the carb or cylinders.
