[FONT="]I have a Mariner 1998 90 ELPTO, Serial # OG748734, which I cant' find anywhere from Mercury material, model# 7-090412GD. I've got a problem with the motor flooding and hard starting. Being a newbie at mechanics, I read tons of info sites and watched videos on You Tube, I thought it was because my carbs were dirty. Being retired I had the time to try fixing it myself, so I put on my big boy pants and dove in. After moving so much stuff out of the way, I finally got the carbs out and found them 99% pristine. I cleaned them anyway. put all back together and it was worse. It won't start with the fuel line connected every time starting out or every time I turn it off. I unplug the fuel line and after a number of cranks it will catch and run fine. Before all this it would happen only starting out and start fine the rest of the day. Also, when I pull the plugs it has a dark oily matter on them and carbon stains on the third plug. Please help! [/FONT]
