So I went out and got a timing light and did a link and sync on this engine per the manual specs which was 5 degrees btdc. Went out on the water and tuned the carbs and got the engine running/idling nicely. The other day I took the cowl off and noticed that on the side of the engine it says that idle should be set to 2 degrees btdc, and then again it says on the air filter cover it says that idle ranges from 6 btdc-2 atdc. I was going to attempt to retune the engine to 2 btdc, but when I started to unscrew the idle timing screw on the side, the engine cut out. I was wondering if anyone has any knowledge on if leaving the timing at 5 btdc would cause engine damage (thing i'm trying to prevent), or if I should just redo the timing and go with the mercury spec on the side of the engine. Thanks!
