Hi, I have a 1996 Tracker(Mercury) 90hp 2 stroke outboard on a 24ft pontoon boat. To keep the story short the boat was running 18-22mph before I took it in for a tune up(it was running a little rough). The mechanic said all 3 cylinders had 120psi, but that carbs should be cleaned and wear parts replaced. At the end of the day he replaced spark plugs, cleaned and replaced wear parts in carbs, new impeller, and new lower unit oil ($950). I also replaced gas tank and fuel lines, before I took it in. When I put the boat in the water for the first time, it ran great (smoother than before), but now it only runs 8-12mph. I have been told by a boater behind me the engine reeks of gasoline. Also one day the boat was running out of gas and the boat started to speed up to the 18-22mph mark before it ran out of gas. Took it back to the mechanic telling him the engine was running too rich and to check his adjustment and he said they were fine. I have found out he isn't a trustworthy mechanic so I wanted further advice. Do you think its running rich, if not what could be causing a reduction in speed.
Thanks,
Scott
Thanks,
Scott
