I have searched a few times for this issue .. and I was not able to find a solution .. so if it is out there and I missed it .. I apologize ..
so here goes .. I bought this boat motor package may long this year .. run good .. everything works .. but this past week I have noticed that when I beech or dock my boat I tilt motor half way up or so .. and in about an hour its all way down if docked .. or on bottom if beeched .. all the research I have done has pointed me towards the fluid level ( checked and is good ) or the pressure release valve ( removed checked new o-rings re inserted ) so I am not sure where to go from here .. is it my pump itself ?? ..
and now what I have noticed in playing with my tilt trim the last couple days .. if I just raise the motor half way.. or 3/4's of the way up .. the motor will slowly lower .. but if I lift motor right to the top then lower it to 3/4's or half way down .. the motor does not slowly go down ..
Also .. when at half or WOT I am not able to trim the motor up until I remove power from the engine .then it lifts ..
so with all that said .. any and all help would be greatly appreciated ..
