GWConrad86
- Jul 6, 2017
- 4
Hey Everyone,
New to the site, great information offered and thought this maybe a good place to ask for some advice. I own a 2001 Mercury XR6 150 HP. Great motor, have had it since March. Runs great until recently where I am confused at the problem. I am pretty familiar with boat motors, have owned three different boats, and have upgrade in horse power each time. Here is the story behind the mystery.
I fish in a bass fishing league and last Wednesday night got down poured on hard. Motor was running fine whole night, trailer it home and put the cover on it. Two days later went up north to walleye fish and put premium gas in her with a can of sea foam and dropped it in the water. Started right up, went to WOT and she was not running right. Barely got on plan and max out a 37 mph @ 4200 rpm. She usually goes 57 mph at 6300 rpm and jumps out of the water. Right there thought water in the fuel or bad gas. Motor idles just fines, start no problem, runs good till about 3000 rpm. So here is the checklist of stuff I check.
A. Took fuel out and put new fuel in, No Change.
B. Checked spark plugs and put new ones in. No Change
C. Check electrical connections for moisture build up. Everything looked good.
D. Check spark at coils and power packs. Everything was zapping good, except for the bottom left cylinder. it was not hitting as many times as the others. Switched a power pack/cable from another cylinder. Same result. Not a weak hit, but not as many times as other ones. Right there I suspect this being the issue, but do not have the tools to check at the time or maybe that is how it is timed.
F. Got home after dealing with issue for 4 days, took the carbs apart needles, jets, floats, and inspected/cleaned. They looked great. idles even better now. No change though.
G. Checked Fuel pump for leak at diaphragm, looks good, fuel filter clean, that's good. primer bulb is good and hardens when squeezed.
H. Looks for blown fuses inside motor housing, they are good. No cracks in wires or condensation on connectors from what I saw.
I am pretty handy with outboard motors and I am scratching my head at this point. It is really frustrating me. How does a motor start good, idle good, but run at 3/4 its power without fuel supply issues? I think it is electrical at this point but do not know where to start. Battery is new, connections are good. could the moisture from the down pour cause this issue suddenly. It was like a light switch.
Any Ideas? Thanks in advance
