Windy Acres
- Jul 6, 2017
- 3
I have a 1998 Mercury Tracker Force 40 HP ELPT Serial # OE333340. It is on a 1998 Sun Tracker Pontoon boat. The only way I can start it is by putting a 12 volt jumper to the yellow and red wire on the key switch. I have chased the red wire on the key switch which should have 12 volts and found it comes from the voltage regulator via a fuse. There is no voltage coming out of the voltage regulator. Does this mean the voltage regulator is bad?
