Hello,
I have been a bit confused on this for a while so have been trying to split the difference.
On adjusting the float levers it has measurement D at 10mm. I am a bit confused as my carb top has a lip and the diagram does not. If i measure from the top of the lip, the top lever is exactly at 10, I i measure from the outside, it is 11mm. The second measurement is dialed in, so just trying to figure out this one schematic unclarity so i can get them to spec!
Ian
Ian
