i have a 99 90hp 2 stroke 3cyl. the oil injection is disconnected and i mix oil when i fuel up. The lower unit is new. I had it gone over and compression tested last year and it got a clean bill of health.
i have had it out a few times breaking in the lower unit per the mfg instructions and had not gone over 3000 rpm until the last trip out. over 3000 rpm i get the overheat alarm. i back off the throttle and its fine. i can idle around and even get up to around 1100 rpms all day long without issue. only when i get up in rpms do i get the alarm. ive done some digging thru the forums and thought it might be the poppet valve. when i called the dealer he said all they ever replace is the diaphram so he ordered me that and the gasket. when i took off the poppet/thermostat cover the spring had pressure on the cover, the diaphram is not torn or deteriorated the passages look clear, i heated the thermostat to check operation and it opened and closed. Would i have seen something obviously wrong with the poppet valve?
so my question is...what else could it be? i haven't put it back together yet (waiting on the thermostat to come in) but i was hoping someone could give me other things to look at while im waiting. There's water coming out the tell tale at idle, and it increases as rpms increase. the lower unit came with the water pump installed, so thats new.
